I have a VLOOKUP formula, [ =VLOOKUP(G2,INDIRECT(F2),2,0) ], where F2 varies, but is a named range. This formula works.
When I try the same with HLOOKUP, [ =HLOOKUP(G17,INDIRECT(F17),2,0) ] the INDIRECT fails. If I put the name of the Range directly into the formula, it works, however if I try to do it where the name of the Range is in F17, failure…
I think this is a bug, has anyone else come across this?
thank you for explanation!
