My batch is as follows:
@Echo off
::“C:\Program Files\LibreOffice\program\scalc.exe” --headless --convert-to csv “C:!MyStuff!PowerShopAA.xlsx”
“C:\Program Files\LibreOffice\program\soffice.exe” --convert-to csv “C:!MyStuff!PowerShopAA.xlsx”
start /MAX “C:\Program Files\LibreOffice\program\scalc.exe” “C:!MyStuff!PowerShop2023.ods”
SO - Before I run the batch I open the 2023.ods which opens fullscreen.
Close the .ods & run the batch which converts some other .xlsx to a .csv and then opens
the same 2023.ods which NOW opens in reduced window (not full screen).
I ‘can’ make it full screen and close it which corrects the problem so that opening it again
it comes up full screen.
Why does ANY .ods or .csv or whatever open in a reduced window AFTER I have run
a convert to csv - that’s where the problem lies.
Changing the scalc --headless to soffice made no difference.
Thanks to both who replied.
