Radio buttons and check boxes not appearing
I am using LibreOffice Version 5.4.2.2 with Linux Mint 18.2.
Radio options and check boxes are not appearing for me in dialogue windows. Is there any fix to this?
Try using LibreOffice from the ppa. It correctly integrates LibreOffice with window manager IIRC.
Thanks for the reply. I uninstalled my previous LibreOffice Calc software, and re-installed from the repository that you suggested. Unfortunately, I have the same issue with this version of the software.
Please see answer in this post for a possible solution.
