Want to copy-paste output values in the same sheet in the same tab which was I using a sum formula.
My problem is to add values using a sum formula.  I just click on one cell and type like =b2+b29.  Once typed it added the total value in b50.
Now I want to copy the value from b50 cell value and need to paste in b2.  I copied but was not able to paste, because it throws the error Reference does not exist.  I know two cell values should be there; then only a formula can work.  But once calculated, not able to paste into any other sheet.
