Libre Office 6.4 Windows 8
App will not open at all it just keeps trying I have to end the process in task manager to stop it.
It only opens in safe mode
Unable to open Libra Office, tried to open ârunâ the page comes up with a black screen and swiftly goes away so I cannot check the settings. 7.1 latest version.
if LibreOffice opens in Safe Mode only, this is a clear indication that your LibreOffice user profile is corrupt and you need to reset the user profile:
To reset the user profile perform:
Right click -> Run
on Windows Start menu - Type
"%ProgramFiles%\LibreOffice\program\soffice" --safe-mode
into Open text field (including the double quotes) - Archive your profile expanding
Advanced
(click on the word Advanced right aboveHelp
button) and clickArchive User Profile
button - Select option
Reset to factory settiings
- Activate
[x] Reset entire user profile
- Click button
Apply Changes and Restart
Note The first 2 steps could be replaced by search the safe mode entry in Windows application start menu
Hope that helps.
If the answer helped to solve your problem, please click the check mark () next to the answer.
I followed your steps for a similar problem and it seems to be fixed. Didnât enjoy having to recreate my toolbars and environment though. Now that Iâve done all that Iâd like to back it up so I donât have to do it again. Iâve looked up how to back up a profile, but canât find any instructions. The wiki page just tells you to do it, not how. Do I just copy the entire user folder and store it?
Thanks.
Just make a backup/copy/zip of %appdata%\LibreOffice\4
(including all subdirs, if your are on windows) while LibreOffice is not started.
I am using windows 8 and I have downloaded the latest version of libre office itâs not opening at all I have been wait for the last 20 minutes please assist
please ask a separate question if the solution above doesnât work for you. Your way to address a separate problem wonât get the deserved answer, if you just add a âme tooâ comment to an answer
Tried all of this. Still will only start up in safe mode. Created exceptions in my anti-virus too. Any advice?
It is probably a graphics issue. Start in Safe Mode but when you get to the screen below, disable hardware acceleration as shown and press Apply changes and Restart.
If LibreOffice opens normally, then click Tools > Options > LibreOffice > View and untick Use Skia for all rendering. Click OK.
Some more info here First steps to take before submitting a bug - The Document Foundation Wiki
Nope, that didnât do it either. Restarted both the app and the system both times just to be sure. Temporarily uninstall anti-virus and that didnât work either, so thatâs ruled out.
I consistently get nothing (except brief spinning pointer cursor), but one time a ways back it got as far as the splash screen. The splash screen splashed, I waited for 25 mins and got nothing. Donât know if that means anything.
I assume you have Windows 8 as you added to this question rather than started your own. Maybe you should explicitly give OS and version and LibreOffice version
Cheers, Al
Dang Google. Youâre right of course. I should be asking about 10. Apologies for wasting your time.
This worked for me
The EarnestAI solution just got my LibreOffice working again (Windows 11).
You should get better performance by enabling Skia and also ticking Force Skia software rendering. This will allow most Skia optimisations but they will be done in software rather than through the graphics card. The About LibreOffice dialogue will show Skia/Raster as below.
Version: 24.2.5.2 (X86_64) / LibreOffice Community
Build ID: bffef4ea93e59bebbeaf7f431bb02b1a39ee8a59
CPU threads: 8; OS: Windows 10.0 Build 26100; UI render: Skia/Raster; VCL: win
Locale: en-NZ (en_NZ); UI: en-GB
Calc: CL threaded
