Problem when closing a dialog and trying to open a new dialog
Good Morning,
I am making an application which requires opening a dialog. After entering proper data in the dialog, it should close the dialog (which i close using endExecute) and open a new dialog. Closing the first dialog is successful. However, when I try to open the second dialog, LO freezes. Here is the LO information:
Version: 7.4.2.3 (x86) / LibreOffice Community
Build ID: 382eef1f22670f7f4118c8c2dd222ec7ad009daf
CPU threads: 8; OS: Windows 10.0 Build 19044; UI render: Skia/Raster; VCL: win
Calc: CL
Good afternoon,
I regularly work with dialogues and do not observe such an effect. Please upload an example of the problematic file and a description of the user’s actions leading to the problem.
The same configuration.
The execute() method returns 1 in when a button of type “OK Button” has been pressed and 0 when a button of type “Cancel Button” has been pressed or when the user hit Enter/Escape respectively.
x = oDlg.execute()
  if x = 1 then
  evaluate_Dialog1(oDlg)
  oDlg2 = load_next_Dlg
  x = oDlg2.execute()
endif
loop_dialog.odt (13.1 KB)
hope this helps.
i will check on this. thank you very much for your assistance. I have not looked at this, but just as a FYI. i am writing my code in Python.
The sample is written in Python embedded in the document.
This example crashes.I have code which connects to personal oracle. Anyone is free to mod this in any way. I would appreciate a way to prevent crashing. Thank you.
TEST_ODS.odb (5.0 KB)
FYI. when the file is opened, a dialog box appears. there are three buttons. the action event of the “Exit” button is what causes the crash.
You don’t need to implement a log-in dialog.
menu.Edit>Database>Conection… Requires Login = ON
I know. I am just using that as an example. The problem is when i close a dialog LibreOffice crashes.
@ztminhas
Remove dispose:
def actionExit(evt:ActionEvent):
    lblResult.Text=str(evt)
    dlg.endExecute()
#    dlg.dispose()
So the other mistake I made was to dispose as soon as I executed the dialog. One should avoid using dispose unless necessary and I have no idea when that use case would be appropriate
In 20 years I never called dispose. I remember some code snippet where it was necessary but I forgot the context and the details.
