Hi, I’m trying to create a planner for a number of months. They are down the left hand side, with the days across the top.
As the number of days in the month change, the days across the top can extend for too long, as there are 31 columns in the sheet.
If that is not clear, please leave a reply, and I will try and explain again.
The attached file shows the problem that I’m trying to solve.
Thanks loads
Martin
) next to the answer. Thanks in advance.
