Using Lilo Starbase Macros in LibreCalc, transfer tables and charts to writer document.
Can you offer an example how to transfer named charts and named tables from librecalc to libre writer document using Macros lilo starbase?
I found this VBA code for microsoft excel to transfer charts into word. How can I modify this code in order to work in libre calc?
Public Sub Copy_Charts_From_2_Workbooks_To_Word()
Dim WordApp As Word.Application
Dim WordDoc As Word.Document
Dim WordRange As Word.Range
Dim WordDocumentFullName As String
Dim wb1 As Workbook, wb2 As Workbook
Dim chObject As ChartObject
Dim i As Long, c1 As Long, c2 As Long
WordDocumentFullName = "C:\folder\path\Word document.docx" 'CHANGE THIS
Set wb1 = Workbooks.Open("C:\folder\path\Workbook1.xlsx", ReadOnly:=True) 'CHANGE THIS
Set wb2 = Workbooks.Open("C:\folder\path\Workbook2.xlsx", ReadOnly:=True) 'CHANGE THIS
'Get existing instance of Word or create a new one
On Error Resume Next
Set WordApp = GetObject(Class:="Word.Application")
Err.Clear
If WordApp Is Nothing Then Set WordApp = CreateObject(Class:="Word.Application")
If Err.Number = 429 Then
MsgBox "Microsoft Word is not installed.", vbCritical
Exit Sub
End If
On Error GoTo 0
WordApp.Visible = True
'Open Word document
Set WordDoc = WordApp.Documents.Open(FileName:=WordDocumentFullName, ReadOnly:=False)
Set WordRange = WordDoc.Range
c1 = 0
c2 = 0
For i = 1 To wb1.Worksheets("Sheet1").ChartObjects.Count + wb2.Worksheets("Sheet1").ChartObjects.Count
c1 = c1 + 1
If c1 <= wb1.Worksheets("Sheet1").ChartObjects.Count Then
Set chObject = wb1.Worksheets("Sheet1").ChartObjects(c1)
chObject.CopyPicture xlScreen, xlPicture
'Paste clipboard to Word document.
'Trap occasional Run-time error 4198: Method 'PasteSpecial' of object 'Range' failed
Do
Err.Clear
WordRange.PasteSpecial DataType:=wdPasteMetafilePicture, Placement:=wdInLine, DisplayAsIcon:=False
DoEvents
If Err.Number <> 0 Then Application.Wait DateAdd("s", 1, Now)
Loop While Err.Number <> 0
On Error GoTo 0
WordRange.SetRange WordRange.End, WordRange.End
WordRange.InsertParagraphAfter
WordRange.Collapse wdCollapseEnd
End If
c2 = c2 + 1
If c2 <= wb2.Worksheets("Sheet1").ChartObjects.Count Then
Set chObject = wb2.Worksheets("Sheet1").ChartObjects(c1)
Do
Err.Clear
DoEvents
On Error GoTo 0
End If
Next
MsgBox "Done"
Using Lilo Starbase
Something from star trek future
I have found a way to get the Dir path, to create a Writer Document, to have open write access on that Document.
I have found a way to copy chart from Calc sheet to Calc Sheet.
I would like to find a method to copy this chart into opened word.
see my early code.
’ XrayTool that helps to investigate VBA objects.
’ Found here: Bernard Marcelly Web site
’ Download word document and click the button inside to install
’ it
Sub LoadingLibraries
BasicLibraries.LoadLibrary("XrayTool")
Sub GetSourceDirUsingOpenDocument
Dim oDoc 'The document on which to work.
Dim s$ 'Temporary string variable.
Dim sOut() 'Output text initially written to the CSV file.
Dim oParms()
oDoc = useDoc
If IsEmpty(oDoc) OR IsNull(oDoc) Then
oDoc = ThisComponent
End If
If oDoc.hasLocation() Then
REM This is assumed to be in URL notation!
s = DirectoryNameoutofPath(oDoc.getLocation(), "/")
GetSourceCodeDir() = s & "/"
'Print GetSourceCodeDir()
Else
Print "Warning, current document has no location"
End If
oBaseContext = CreateUnoService("com.sun.star.sdb.DatabaseContext")
sFileName = "results"
sURLInitial = GetSourceCodeDir() & sFileName & ".odt"
n = FreeFile() 'Next free file number
Open sURLInitial For Output Access Read Write As #n
For i = 0 To UBound(sOut())
Print #n, sOut(i)
Next
Close #n
Sub CopyChartstoWriter
' Definitions of variables
Dim oSheet 'Sheet containing the chart
Dim oCharts 'Charts in the sheet
Dim oChart 'Created chart
Dim sName$ 'Chart name
Dim oChartDoc 'Embedded chart object
Dim oDiagram 'Inserted diagram (data).
Dim oCalcDoc
sName = "statChart_1"
oSheets = ThisComponent.getSheets()
oSheet = oSheets.getbyName( "Graphs_stat" )
oCharts = oSheet.getCharts()
oChart = oCharts.getByName(sName)
' oChart.setRanges(Array(oAddress))
oChartDoc = oChart.getEmbeddedObject()
oDrawPage = oSheet.getDrawPage()
oZero = oDrawPage.getByIndex(1)
'The next three lines could be used to check that oZero is a chart
EmbObj = oZero.EmbeddedObject
Component = EmbObj.Component
print Component.supportsService("com.sun.star.chart.ChartDocument")
'Select the chart
ThisComponent.CurrentController.select(oZero)
'Get ready to do dispatcher calls
frame = ThisComponent.CurrentController.Frame
'Copy the selected chart
dispatcher.executeDispatch(frame, ".uno:Copy", "", 0, Array())
'Go to the cell B3
dim args3(0) as new com.sun.star.beans.PropertyValue
args3(0).Name = "ToPoint"
args3(0).Value = "$B$3"
dispatcher.executeDispatch(frame, ".uno:GoToCell", "", 0, args3())
'Paste the chart
dispatcher.executeDispatch(frame, ".uno:Paste", "", 0, Array())
end sub
FTR: tdf#144191
Isnt it unkind to post the same topic in several forums at the same time?
https://forum.openoffice.org/en/forum/viewtopic.php?f=20&t=106011#p515159
At first, I was posting to Stackoverflow, but I didnt found much support about LO base macros. So, then I posted here. However, I didnt know If I will receive help from here. So I posted to openoffice forum too and then help came from both places.
So, now, I know.
Copy and paste will do.
Two bugs prevent a macro free solution:
If charting in database reports would work as in LO 4.x, we could bind the spreadsheet to a database document and use a report with charts. Charts in reports would provide an additional feature. A report can generate individual charts for each grouped category, e.g. one chart for each region, time interval, sales point etc.
Please don’t include the VBA code, it’s not useful for LibreOffice :-).
Test this:
Sub CopyChartToWriter 'copy the chart from the Calc sheet to the Writer document
dim oDoc as object, oSheet as object, vChart as variant, data as object
oDoc=ThisComponent
oSheet=oDoc.Sheets(0) 'sheet with chart
vChart=getChart("MyChart1", oSheet) 'the chart named for example by right-mouse and Name, or from menu Format/ Name
if NOT isObject(vChart) then 'the chart doesn't exists
msgbox vChart & " - doesn't exists!"
exit sub
end if
oDoc.CurrentController.ActiveSheet=oSheet
oDoc.CurrentController.Select(vChart)
data=oDoc.CurrentController.getTransferable() 'LibreOffice internal Ctrl+C
rem Writer document
dim oDocWriter as object, sUrl$, oVCur as object
sUrl="private:factory/swriter" 'new writer document
'sUrl=ConvertToUrl("d:/documents/example.odt") 'or your writer file
oDocWriter=StarDesktop.LoadComponentFromUrl(sURL, "_blank", 0, array()) 'open Writer document
rem paste chart to the end of the visible cursor
oVCur=oDocWriter.CurrentController.getViewCursor 'visible cursor
oVCur.collapseToEnd
oDocWriter.CurrentController.Select(oVCur) 'select visible cursor
oDocWriter.CurrentController.insertTransferable(data) 'Libre internal Ctrl+V
Function getChart(s$, oSheet as object) as variant 'returns the chart as object (if chart exists); or returns the chart name as string
dim i&, o as object
for i=0 to oSheet.DrawPage.Count-1
o=oSheet.DrawPage.getByIndex(i)
if o.Name=s then
getChart=o 'return the chart as object
exit function
end if
next i
getChart=s 'return the name of the chart as string
End Function
Problem…
Steps to reproduce Bug"
Gender Female Male a1 1 1,2 a2 2 2,35 a3 2,24 2,02 a4 2,58 3,94 a5 3,6 3,77 a6 3 2,75 a7 2,65 2,51 a8 3,1 2,58 a9 3,7 2,35 a10 3,87 3,94 a11 3,78 3,77
Run the following Macro code
Sub CreateCalcWithSimpleChart
Dim oRect 'How big is the chart
Dim oAddress 'Address of data to plot
Dim oTitle 'Chart title object
Dim sDataRng 'Where is the data
Dim oCalcDoc
' it is needed to define Point and Size in order to
' change Position and Size of Chart Objects
Dim Pos_Chart As New com.sun.star.awt.Point
Dim Pos_Title As New com.sun.star.awt.Point
Dim Pos_SubTitle As New com.sun.star.awt.Point
Dim Pos_xTitle As New com.sun.star.awt.Point
Dim Pos_yTitle As New com.sun.star.awt.Point
Dim Pos_Legend As New com.sun.star.awt.Point
Dim Size_Chart As New com.sun.star.awt.Size
Dim Size_Title As New com.sun.star.awt.Size
Dim Size_SubTitle As New com.sun.star.awt.Size
Dim Size_xTitle As New com.sun.star.awt.Size
Dim Size_yTitle As New com.sun.star.awt.Size
Dim Size_Legend As New com.sun.star.awt.Size
'Dont Forget to Define "Name of Sheet
oSheet = oSheets.getbyName( "Graph_stat" )
Chart_XPos = 0
Chart_YPos = 17000
Chart_Width = 16000
Chart_Height = 10000
Chart_New_XPos = Chart_New_XPos + Chart_Width + 900
'Creation of objects into variables
oCalcDoc = CreateCalcForChart()
sName = "stat1"
sDataRng = "D17:F28"
oAddress = oSheet.getCellRangeByName(sDataRng).getRangeAddress()
oRange = oSheet.getCellRangeByName( sDataRng )
'The size of the whole chart
If NOT oCharts.hasByName(sName) Then
oRect = createObject("com.sun.star.awt.Rectangle")
oRect.X = Chart_New_XPos
oRect.Y = Chart_YPos
oRect.width = Chart_Width
oRect.Height= Chart_Height
oCharts.addNewByName(sName, oRect, Array(oAddress), True, True)
End If
' Getting the Chart for manipulations
oDiagram = oChartDoc.createInstance("com.sun.star.chart.ChartDiagram")
oChartDoc.setDiagram(oDiagram)
oDiagram = oChartDoc.getDiagram()
'Inside the Chart, Setting Position and Size of the Diagram
oChartDoc.RefreshAddInAllowed = True
Pos_Chart.X = 300
Pos_Chart.Y = 1200
Size_Chart.width = Chart_Width - 800
Size_Chart.height = Chart_Height - 1500
oDiagram.setPosition( Pos_Chart )
oDiagram.setSize( Size_Chart )
end sub
Your code which I changed a little, says vCard problem
Sub CopyChartToWriterA 'copy the chart from the Calc sheet to the Writer document
dim oDoc as object
dim oSheet as object
dim vChart as variant
dim data as object
' dim sUrl$ as object
dim oVCur as object
sName = "a1"
vChart = getChart(sName, oSheet)
rem Writer document
' sUrl=ConvertToUrl("/document.odt") 'or your writer file
oVCur.collapseToEnd
The procedure CreateCalcWithSimpleChart sets the property PersistName, so in the function getChart I changed the condition. There is also example for xray in the getChart → to view a properties of the chart.
I hope the vCard is the variable vChart
vChart=getChart(…) → you must also copy the function getChart to your macro module
Example for copy the chart created by the procedure CreateCalcWithSimpleChart is here
graf-pokus.ods (17.2 kB)
My System persists to say that no “stat1” chart exists.
If i remove the if condition, the writer document is opened but nothing is copied.
I have stucked to “name” condition.
I found out that chart also has Description and Title as whole Chart. I set them all as “stat1”.
The same error.
I filed a bug in bugzilla.
In your case, my function set properly the chart name - did you manually checked that or it is empty?
Test again
graf-pokus.ods (12.1 kB)
Only two steps: 1) Tools/ Macros/ Run macro… → from the file graf-pokus.odt the macro CreateCalcWithSimpleChart
2) Tools/ Macros/ Run macro… → from the file graf-pokus.odt the macro CopyChartToWriter
First step will put the chart to the sheet, second step will copy the chart to the new document. In my computer it is functional. Unfortunately I don’t know how to help you more.
I did it with your help (a big thanks). I will post the solution in a while (to tidy the code). I will accept your post as solution.
This macro code is working for me in your example. Can you check please that this code is working too for you? Thanks.
Doc = ThisComponent
oZero = oDrawPage.getByIndex(0)
'Select the chart
Doc.CurrentController.select(oZero)
data=Doc.CurrentController.getTransferable() 'LibreOffice internal Ctrl+C
rem Writer document
oVCur.collapseToEnd
end sub
Yes, it works also for me. But use functional check that oZero is a chart:
rem check that oZero is a chart
if oZero.supportsService("com.sun.star.drawing.OLE2Shape") then
EmbObj=oZero.EmbeddedObject
Component=EmbObj.Component
if NOT Component.supportsService("com.sun.star.chart.ChartDocument") then 'not a chart
exit sub
end if
else 'oZero is not a chart
exit sub
end if
Very helpful! Thanks again.
I am struggling with this now… (maybe to open a different topic?)
About DrawPages:
a) Charts (which store Charts in a sheet) provide a list with object names as string e.g .Charts.getByName(“xx”) or Charts.getByIndex(0)
b) I havent found something similar with DrawPages.
c) The weird thing IS that Draw Objects DO have names e.g .“Object 1” but initially, DrawPages nowhere stores them as an index string. This is accessed after specifying index of Chart eg. getByIndex()
Note this:
’ Doc.getDrawPages.getByIndex(0).getByIndex(0).Title
’ Doc.getDrawPages.getByIndex(0).getByIndex(0).Description
’ oSheet.getDrawPage().getByIndex(0).PersistName
What I would like to do:
I would like to itirate through name of objects (charts) BEFORE Index of Drawpages.
Why? Because it is more “safe” solution.
If Calc document have other draw objects, this may create confusion. I would like all calc charts to be named with specific names.
So, Is there a solution ?
How can i be assured that only named-specific charts will be appended to the Writer document?
I tried to use charts.getByName(“blablabla”) but Doc.CurrentController.select refuse to select it.
Is there any other way to copy paste a chart object as Chart in libre writer from Calc except Drawpages?
Anything else?
