Dear all,
imagine you have a serie of points with a certain (fixed) coordinate between them. I then have an additional point which might end up sitting between 2 coordinates of the above mentioned serie. What is the best way to find the delta between the serie and the point?
Here’s an example:
Serie:
x y
0 2
1 4
2 5
3 7
4 9
Point:
x y
2.5 8
In this case the result should be the delta between 8 and the interpolated value of 2.5 from the serie between 2 and 3 hence: 8-6 = 2
Of course, I don’t know a priori where the point would end up being and I cannot simply use a linear interpolation of the whole serie. What I would need is a linear interpolation of the interval of the seri (0-1, 1-2 …) and the the delta between the point and this linear interpolation.
Thanks
