Lubuntu 20.04, LibreOffice 6.4.3.2. My Samsung ML 1610 printer does not print text correctly through LibreOffice. It prints graphics correctly.
asked 2020-06-11 13:07:31 +0200
Hitendra gravatar image
updated 2020-08-14 21:25:40 +0200
Alex Kemp gravatar image
The printer works fine with other software such as Thunderbird Mail and qpdfview. It was working fine in the earlier version of LibreOffice. Kindly let me know what to do?
answered 2020-06-11 14:13:45 +0200
Opaque gravatar image
updated 2020-06-12 12:36:46 +0200
there have been various problems reported on initial installs of LibreOffice on Ubuntu 20.04 based systems as there are:
  • Offline Help doesn't not load
  • PDF exports not working
  • Image processing not working
  • Printing issues
Most of them could be fixed by the procedure described in answer to question https://ask.libreoffice.org/en/question/242188/cannot-print-anything-exporting-to-pdf-produces-blank-pdf-lubuntu-2004/
Hope that helps.
answered 2020-06-12 06:32:58 +0200
Thank you! After reinstall of LibreOffice as suggested in the link, it is working perfectly. Thanks for your time.
This is not a forum to comment a question by providing an Answer, which doesn't answer the original (in this case your own) question. The proper way to indicate an answer solved your problem is to cklic the check mark (✔) next to the answer, which fixed a problem.
Opaque gravatar imageOpaque ( 2020-06-12 12:36:25 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2020-06-11 13:07:31 +0200
Seen: 527 times
Last updated: Jun 12 '20
